Evinrude ignition trouble
Tinnydriver
I have an '82 Evinrude 35 that has a puzzling and regular engine miss. At low speeds both cylinders seem to drop ignition (?) at about ten second intervals, this interval decreases to about 5 seconds at full throttle ... has anyone got any suggestions of where to start tracking this problem?<br />Thanks
Walker
Re: Evinrude ignition trouble
Could be running lean. Does that motor have adjustable carbs. May be time for a carb overhaul.
Tinnydriver
My 35 has a single carb, plugs don't look like a lean run but will overhaul anyway as it is probably well overdue for this. You might be right as the miss opens out to a 12 second interval when the mixture screw is opened 1/2 a turn. Thanks for the advice
Joe Reeves
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)<br />(J. Reeves)<br /><br />Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.<br /><br />Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.<br /> <br />Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
Tinnydriver
Thanks Joe, I am working without a manual so your help is much appreciated. It's a fine day here so I'll get the boat to the water and commence with resetting the carb now that I have it cleaned out and with new gaskets/ seals.
