Hi to All,<br /><br />Today I went out to try out a new bow mounted 40# all terain trolling motor. Monitored the amps and voltage draw on battery. I decided to check voltage on cranking battery it was 12.3 volts. I then started the engine and it stayed fairly constant. I then put it in gear and ran it half speed it went to about 12.5. I thought it should have been higher if my engine is charging. I'm not even sure it has a charger, it does have a <br />rectifer so I'm thinking it has a charger. Any input will be appreciated.<br /><br />Thanks,<br />Beck
