restoring 72 johnson
billyt
I just today got my hands on a 1972 65 hp Johnson. She's old, but solid. I'll probably take her to a marine shop to do the carb job and water pump as I don't really have access to a shop or tools. I want to polish her up externally. Is there a special paint I need to use on the cowling? What about the shaft? The compression on all 3 cylinders is around 125. Once I've got the tune-up done, is there anything else I really need to check, or just take her out and fire her up? thanks for the site and the input!<br />blt<br />(I'm in Texas and I feel like Kojak, but I finally got all the proper paperwork from TPWD to get it titled!)
Solittle
Re: restoring 72 johnson
Plugs, thermostat & change the gear oil (new gaskets for fill & drain plug) should do it.
Kenneth Duke
Bait Fishingpole and a TwelvePack of good beer should do it just fine have fun and enjoy it.
papasage
this is probabley a eletric shift . if so put the eletricshift oil in it or you will have probablems . you will probabley have to git it from a dealer . the heavy weight is to thick for the pump and want shift .
billyt
The cowling does say Hydroelectric drive. Is that what you mean? blt
