I D Johnson
jfm1
:confused: Just wanted to find out if anyone out there knows how to Id the year and hp of a Johnson motor without the model# can you tell by serial # ? Thanks for any help
Paul Moir
Re: I D Johnson
Given the number of serial numbers posted on Iboats, it's somtimes possible to estimate the year an outboard was built, but it's impossible to determine it's hp. What's your serial number?
beach
Re: I D Johnson
Hve you checked the motor for other areas the model might be stamped eg. freeze plugs
jfm1
Re: I D Johnson
Paul the serial # is J2829652 mod.FDL-12R the motor is olive green as well as the housing and lower unit no overspray could the factory made a mistake on the model # ? 12 instead of 21 thanks for any and all help PS the ser # is also on the plug
dk990496
Re: I D Johnson
a FD-12 is a 18HP year is 1958 thats the close's i came to
jfm1
Re: I D Johnson
UPDATE I know the mod.# FD12 is a 1958 18hp after a number of hours on different sites I found a catalog from 1970 and the pic on the catalog is what my motor looks like The pic from 1958-1969 are not the same / Why it has that mod# ? is beyond me Again thanks for the input I'm so :confused: :confused:
Paul Moir
Re: I D Johnson
Does the serial number on the transom clamp match the one on the the freeze (actually welsh) plug beach is talking about? If not, perhaps the transom clamp was salvaged from an older 18hp. It's not unheard of for those engines.<br />Also, be wary that your hood could be from a different engine, as they get swapped a lot over time.
jfm1
Re: I D Johnson
The ser.# does match But in no way would a hood from a 1970 fit on a 1958 everything matches a 1970 motor shape color ect.
Paul Moir
Re: I D Johnson
Oh, that serial number homes in on 1967. What you may have is a misprint: 1967 would have been a FD-21, which is a 20hp.<br /><br />J2820205 - 1967<br />J2827881 - 1968 (mabey a mistake)<br />J2828428 - 1967 <br />J2829652 <br />J2833232 - 1967<br />J2835115 - 1967<br />J2835928 - 1967<br /><br />Sounds like a unique rig anyway!
jfm1
Re: I D Johnson
Thanks Paul, it is a nice motor runs great so far I want to put in a new impeller and seals this winter its hard to get part if you don't know what you got lol Thanks again Paul
