There was a software upgrade for certain 2001 modles that improved starting, Your dealer can download it from the factory website, then install it on your motor.<br /><br />Make sure you have adequate capacity batteries in your boat using the factory cable connections. You want a 750 CCA or better battery so the motor spins over fast enough and that the EMM voltage is above 9.6V.
Aquamann,Does it really say that?I don't doubt you,but it will help me convince customers not to just turn and crank.I tell them to at least let SystemCheck run,then crank.<br /><br />DHP
Dhadley,<br /><br />Guess I miss your point. (grin).<br />No,at start position motor should not crank.<br />Of couse this a Ficht,though.<br /><br />DHP
