damn my engine is dead...
stingraymax
Well i installed and hooked up my "new ' secondhand engine .<br />But when I tried to fire it up .... the systemcheck sound and lights came on but that was all, nothing.....<br />The starter is'n even turning... and yes the batery is full.<br /><br />I checked the fuse and that one is good.<br /><br />Can somebody tell me where I can measure some point to figure out what the problem might be.<br /><br />Thanks.<br />It's a 1999 Johnson 90Hp<br /><br />Stef
Joe Reeves
Re: damn my engine is dead...
Check to see that you have 12v being applied to the "B" (battery) terminal of the ignition switch.<br /><br />In the START position of the ignition switch, 12v should register at the ignition switch "S" (solenoid) terminal. Does it?
Solittle
Stef - If you are going to fiddle with that engine yourself best gei the OMC shop manual for it.
boltbreaker
Can you turn the flywheel by hand? Try removing the plugs and see if it will move. It may be terribly flooded or stuck. Keep us posted!
rabidfish
Are you sure it's in neutral?
joblo33
Could be a dead starter solonoid
sandspike
turn the key on and try to pull start it if you can. if it starts you know it not the motor and trace from there .
stingraymax
Well I think it is the starter solonoid. I will bring it in on monday and hope it is only that...<br /><br /><br />Thanks for the help.
