Re: Tread size for remote fasteners
Hi Bjorn....we'll try to help ya' out here. I'm not real sure to what you are referring to sooooo,<br /><br />At the engine, there should be an anchor bracket on each side of the engines lower pan. One is for the throttle cable on the port side and the other anchor the shift cable, on the starboard side. The adjusting trunion on each cable, looks like a large thumb wheel, fit into the anchor slots and are held in place by a tab on the anchor bracket. The tab is held in place by a screw.<br /><br />At the throttle side, the casing guide on the end of the control cable, slips over the throttle control post, alittle *** sticking up, bout' halfway back and to the bottom of the pan, and is held in place by a keeper.<br /><br />At the gear shift handle, you will notice a slotted hole. The casing guide on the shift cable should have a pin with a small pin through it. The pin goes through the gear shift handle hole and turns. The small pin holding it in place.<br /><br />It's really hard to put all this in words....pictures are much better. If you have a dealership close, I would take the rig there and see if they can point you in the right direction.
