Singlepole
- Joined
- Jun 24, 2005
- 14
1958 Evinrude Lark 35514 50076 <br />has been in storage for 10 years, looks as though the heads have been off and replaced.<br />Put it in a bucket of water and cranked it over with some new fuel. It fired up good and ran smooth but then started to back fire. I replaced the spark plugs (had J4 and I was told it should have J8 but I was scared to put em in so I went with 6) and set the points to .020 replaced a cracked coil, that was still working but looked bad. Then started it again, ran smooth for about a minuite then back fired and sheared the woodruff key. I searched the world (seemingly) for a new key and finally ended up making one. Put it back together, cranked it up again with the same results. I was given advice to open the point gap a bit, but thought I should check here first. Any one have any ideas or advice?
