1960 40 hp johnson rds22
Status
Not open for further replies.
cluke3
what direction would the armature base rotate to full spark advance i am trying to adjust the control rod collar to provide 1/32 clearance from the pivot pin I have the manual but cant figure it out.
Paul Moir
Re: 1960 40 hp johnson rds22
Welcome to Iboats<br />Counterclockwise. There should be a stop formed by a foot on the casting that holds the spark plug wires that strikes a tab sticking out of the block to stop the spark at full advance.<br /><br />You're trying to adjust the stop that continues to open the carb once the armature plate has hit the full advance stop? If so, I just adjust it so it begins to take over at this point.<br /><br />Or are you trying to synchronize the carburetor with the spark advance?
cluke3
trying to synchronize the carb with spark advance
cluke3
clymer johnson outboard shop manual 1956 to 1972
Paul Moir
Ah, that explains it. Does what I posted make sense then?
cluke3
so when the advance is touching the stop the throttle should be wide open
Paul Moir
No not at all.<br /><br />The throttle should just begin to open when the pointer on the manifold lines up with the mark on the cam (refer to the picture).<br /><br />When you have that set correctly, the throttle should be about 3/4 open when the advance hits it's stop. At that point, the auxiliary linkage running from the vertical throttle shaft to the cam follower roller takes over, opening the carb the last 1/4 or so.<br /><br />FYI, The most fuel-efficient operation happens when the advance has hit the stop, but before the auxiliary linkage takes over.<br /><br />If you want, I can take a picture of what I'm calling the auxiliary linkage.
Paul Moir
<br /><br />Before the armature plate hits the stop, that link should do nothing at all.
Paul Moir
No trouble. As you might have guessed by that hand made brass link arm, I'm kinda big on these engines. :D
cluke3
no thermostat in this engine do i need it<br />pretty hot here in tx.
Paul Moir
It'll run/idle a lot better and last longer if you have it in. New one's around 10 bones.<br />PN 5005440 from the dealer.<br />PN 18-3553 from Iboats/NAPA Autoparts, etc.<br />There should be a little plastic cup in there, followed by a plunger and spring. If it's all gone, go get all the parts from the dealer. Aftermarket only has the 'stat itself.<br /><br />Might wonder why it's missing - if the impeller hasn't been done recently it's time to replace it.
cluke3
got the thermostat parts except for the seal that gos under the cup anything else that will work in its place
Paul Moir
You might find an o-ring to fit at the local hardware store. Really, it's not that critical. It wouldn't be the end of the world if it leaked a little.
cluke3
one more question this rds22 has a 1964 powerhead on it ser#40473s what oil mix is best 24-1 or 50-1
Paul Moir
You may go to 50:1. 1964 was the first year for 50:1.<br /><br />Actually, there doesn't appear to be any design changes that could conceivably affect fuel/oil mixture on that engine after 1961 (I think) when they switched the rod small end bearings to roller. But '64 is the "official" year for 50:1. 87 octane gas and TC-W3 outboard oil, and don't forget to decarb regularly.
cluke3
got everything set now it is spitting back thru carb at idle
Status
