Joe Reeves
- Joined
- Feb 24, 2002
- 13,262
Re: Power Pack Question
Since you've now replaced the obvious faulty stator with a good one (hopefully a new one?), do the following.<br /><br />Make sure that all engine wiring is properly connected such as.... brown to brown, brown/orange to brown/orange etc etc, then (again) disconnect the large RED electrical connector at the engine. Remove the spark plugs and crank the engine via a jumper at the starter solenoid, testing for spark.<br /><br />If you now have spark, in all probability the ignition switch is shorting out, in which case, replace it.<br /><br />If still no spark, either the sensor in the timer base is faulty, the powerpack has also failed, or a internal break exists in the wiring from the timer base to the powerpack.<br /><br />You can test the continuity of the sensor wires and the resistance of the sensor itself at the same time by disconnecting them from the powerpack and connecting a ohm meter to them, set to Lo Ohms. You should obtain a reading of 15.0 ohms +/- 5.0 ohms.<br /><br />Then.... change the ohm meter to read high ohms and connect one meter lead to ground, the other lead to one of the timer base leads and then the other lead. You should obtain NO reading. Any reading here would indicate the lead or sensor is faulty and is grounded.
