no power help
syl
i have a 1978 Johnson 115 its starts good its timed good but it has no power wen i put it in gear and it sucks losts of gas like crazy my carbs are good so i dont know what to do can any one help me plezz thanks ......
jfm1
Re: no power help
did you do a compression and spark test ? whats your plugs look like ?
syl
Re: no power help
yes i did and the compression is good and the spark is good but one side is of the spark plug is black so i dont know it relly has no power and suck gas like crazy....
Blueclaw
Re: no power help
If everything is good then it should go!<br /><br />You said the timing is good. Does the timing advance work?<br /><br />You said the carbs are good. Have you tore them completely down and cleaned them and set the floats?<br /><br />You said the spark is good. How did you test the spark?<br /><br />You said the compression was good. What were your numbers?<br /><br />More info!
syl
Re: no power help
Yes I completly removed the carbs and cleaned them. Yes the timing advance works. The comprestion is beteewn 120-130. I tested it by holding the spark plug close to the motor and I have a nice blue fire. I working on it now can you answer me as soon as posible. Thanks
Blueclaw
Re: no power help
check to make sure the choke plate aren't closed. <br /><br />Do you have a manual?<br /><br />Did you do a link and sink on the carbs?
syl
Re: no power help
nop every thing is good there so i dont know what els?
Blueclaw
Re: no power help
from what you're saying everything is perfect but you wont answer questions. do you have a manual?did you do a link and sink? what is your timing reading? <br /><br />If the motor is sucking in massive amounts of fuel, your carbs must be screwed up, or you don't have that good spark, you think you do. The plugs have to be installed and a spark checker is needed to determine if you actually are getting good spark under load. Did you put a timing light on each wire and watch if you were getting controlled spark to each cylinder? When you took the carbs apart did you rebuild them or just clean them?
syl
Re: no power help
ok i got it working it was the CDI i change it and all was good went on the river and camp there for the night and then the nex morning went for a ride and my motor blow up its finish now that relly sucks so i got to look for a other mortor if u know any one let me know plez and THANKS you verry much for your help.
