Re: 70 johnson trim
Welcome to the forum!<br /><br />Your toggle switch may have gone bad. You cant fixem have to buy a new one.<br /><br />Your pump motor sounds to be ok.<br /><br />The blue and white wire is for up and the green and white wire is for down. the black is for ground.<br /><br />You can use a jumper wire from the ground and touch the two other wires one at a time and see if it goes up and down. if it does replace the switch.<br /><br />Good luck!
