head gasket and deflectors
aanda6
1977 115HP crossflow.<br />No water pumping.<br />replaced water pump. impeller. key is in properly.<br />removed and cleaned tstats.<br />if blown head gasket could the pressure stop water from pumping through block? I read that in another post.<br />do I only need to replace head gaskets and deflectors , or is there more to do?
ddbyrd3
Re: head gasket and deflectors
Yes when you pull the heads you need to change the deflectors and head gaskets.. But since you are there, you might as well pull the head covers and make sure all of the water passages are clear especially since these cool the top of the combustion chamber....<br /><br />Does that motor have a pee hole, are all of the lines clear? If the impeller at one time came apart, maybe a peice got in there and plugged the hole, hose, whatever.....<br /><br />Also, if you are unsure of the age of the T stats, I would replace it (them) all together, cleaning them and replacing them is not a fool proof way of making sure they are working properly..<br /><br />A few extra $$$ for endless peice of mind.....
aanda6
thanks. will replace the tstats. no pee hole on that motor. manual doesn't show where all water passages are in top are they easy to find
Cortes165
Just remove the head cover. Underneath it will look like a little maze that is built right into the head. Water enters on one end, zigzags through all these passages and out the other side. Once you pull the cover, it's easy to understand.
