Re: Slip calculator- speed
1984 sportcraft center console 20'2" x 7'6" 2500lbs empty hull weight<br />1991 johnson looper v6 225 with sea drive bracket<br />600 pounds on a 24" setback from hull.<br />anti-cav plate is 2 inches above keel.<br />40 gallons fuel, 1 group 29 battery, 1 12 pound anchor with chain, 100 pounds misc crap.<br />me 220 pounds, and one red 32 ounce gatorade
<br /><br />v hull with pad in back, and very mild deadrise, 10 degrees<br />smart tabs mounted on very outer edges of transom<br /><br />4 blade stainless "renegade" prop 19p x 14 diamater<br /><br />52.0 mph, 5800 rpm,gps verified with engine trimmed out to max, on a semi calm day with 1 foot chop and 10 mph breeze.<br /><br />boat was "chinewalking" at this speed, bouncing from left side to right side an back...<br /><br />im using 2.24 as gear ratio, but im not sure...and im using 49 as theoretical speed...<br />
this boat speed calc says im getting NO PERCENTAGE SLIP. it says that i have a NEGATIVE 6% slip..... <br /><br />is that even possible?
