Slip calculator- speed
Realgun
Prop slip calculator <br />I love this one.<br /><br />Got my boat finished enough to do speed runs and know whats going on.<br /><br />The tach seems to work fine yea! Hard to find the 20 pole tach's for the older Force motors.<br /><br />Anyway got a reeding on tach of 4600 WOT. Prop is a 15 with a good cup so you use 16 in calculator.<br /><br />Reading on speedo is 32mph. Slip calcs to 9% That seem correct to me as at 15% slip its 30mph. I am happy with that.
phatmanmike
Re: Slip calculator- speed
1984 sportcraft center console 20'2" x 7'6" 2500lbs empty hull weight<br />1991 johnson looper v6 225 with sea drive bracket<br />600 pounds on a 24" setback from hull.<br />anti-cav plate is 2 inches above keel.<br />40 gallons fuel, 1 group 29 battery, 1 12 pound anchor with chain, 100 pounds misc crap.<br />me 220 pounds, and one red 32 ounce gatorade :) <br /><br />v hull with pad in back, and very mild deadrise, 10 degrees<br />smart tabs mounted on very outer edges of transom<br /><br />4 blade stainless "renegade" prop 19p x 14 diamater<br /><br />52.0 mph, 5800 rpm,gps verified with engine trimmed out to max, on a semi calm day with 1 foot chop and 10 mph breeze.<br /><br />boat was "chinewalking" at this speed, bouncing from left side to right side an back...<br /><br />im using 2.24 as gear ratio, but im not sure...and im using 49 as theoretical speed...<br /> this boat speed calc says im getting NO PERCENTAGE SLIP. it says that i have a NEGATIVE 6% slip..... <br /><br />is that even possible?
Paul Moir
Ought to be 1:1.86 (14:26) on that bad boy.<br />Running the 52.0mph data with a 19" prop, I get 7.5% slip. Which I gather is pretty good. :)
walleyehed
Mike, if it's chinewalking with the tabs, you need to move the mounting lugs back on the tab end of the struts...
phatmanmike
only chinewalks when its just me in the boat, but it sure does fly for such a heavy beast.<br /><br />paul, thanks for the info. that sounds more like it.<br /><br />kenny, i think your talking bout placing the tabs at more of a 30 degree angle instead of the standard 25 degrees? moving them downwards with more pressure?<br /><br />right bnow the boat is all apart, motor is in the bed of my truck and transom is getting some new wood and glass, so testing will be a while. thanks guys.<br /><br />and thannk YOU, mr.realgun !!!
Realgun
Anything for the cause. :D
Realgun
I need a cheap 115 that 85 is ok but I feel the boat can go way faster. That USCG 180 degree wheel turn test barly unseats the boat and you can do a full turn of the wheel at WOT and thats fun! The boat really handles well and rides good to had a 1-2 foot chop and the boat barely notices it. Ok it notices but its nice.
