Old Johnson TD 20, SN#680419
hobo1240
Just started to tear this engine down and it is good shape. However, I'm looking for a one stop location for gaskets, paint and decals. Also a carb kit would be in order as well. Does anyone target this engine specifically? Thank you.
hobo1240
Re: Old Johnson TD 20, SN#680419
Thanks, Mike! Looks like it may take more time to find parts, etc. than to do the rebuild.
MCM
Probably got that right, <br /><br />GOOD LUCK,<br />Mike ;)
Paul Moir
The S/N says it was made in 1948. No differences between '46 and '49 as MCM pointed out, just thought you might like to know.<br />Decals & paint:<br />www.nymarine.ca<br />Decals:<br /> http://www.americanoutboard.com/ <br /><br />Carb kit isn't available, but if you're float is falling apart, there's a merc float that can be made to work.
hobo1240
Thanks fellas.<br /><br />I going to pull the head today to see if the coil and points are in decent shape. Any tricks to this? Like how do I keep the prop from turning when loosing the bolt on the head? Jam it? Clock wise or counter clokwise? Wish me luck.
MCM
Hi hobo, Hey that motor's got ten years on me but I found some old posts relating to your motor, there not as old as the motor though but you might find some usefull info.<br /><br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi <br /><br />Best of luck,<br />Mike ;)
