wanted to know if any of you has had any experence with the 8 bolts either loosining or shearing off and allowing the endcap to lift and rotate.in this case enough to let the stator get into the flywheel and generally make a mess out of everything....someone must have knew because the replacement bolts from omc of course are 8 dollars each...no u read that right,8 dollars x 8.thought maybe it was one of those dirty little secrets the tech people didnt speak of except at the annual christmas party....
