Starting issue
JasonB
1976 Johnson 85hp V4<br /><br />Went out this morning to put her away for the winter and she won't start. You turn the key and the Solenoid clicks hard, but no starter. I jump some power straight to the starter and it spins counter-clockwise (backwards?).<br /><br />Batery is wired properly and fully charged. Choke and trim work ok. Started fine when it was parked.
JB
Re: Starting issue
You have a bad connection or cable in the high current circuit for the starter, Jason, or maybe a bad solenoid. My bet is on the battery ground cable to engine block connection, but it could well be one of the others.<br /><br />The "no start" FAQ covers troubleshooting the starter circuit.<br /><br />Good luck. :)
