can i take out the lighting coil and still have a running engine?
LOLHJ
Hey all,<br /><br />I have an '86 mariner 30 hp engine, I have a rubbing noise from under the flywheel and would like to eliminate this as a possiblity, anyways I want to take out the lighting coil- since I dont use it and the wires to it are capped off. Is there any problem with doing this?<br /><br />
<br /><br />Just want to make sure everyone knows what I mean. Thanks everyone.<br />-John
petryshyn
Re: can i take out the lighting coil and still have a running engine?
how about taking a little paint or white-out and paint these flat surfaces. Reinstall the flywheel and give it a few turns. Remove flywheel and address the offending (scraped) component?<br />
Yepblaze
Hey Schematic, how could just adding a few arrows and removing one make the filesize of that image 10 times larger?
LOLHJ
Thats an idea, but I dont know if they would be scraped unless they were at a high rpm such as when running or idling.<br /><br />Would it be possible to simply remove the lighting coil? Again i dont have a need for it.<br />Thank you!<br />-John
petryshyn
yeah it'll run without........but thats cheating<br /><br />Yepblaze<br />you had to catch me didn't you! The original was a .JPG I wanted to save it as a GIF but a slip of the mouse and I saved it as a JPG. My JPG's are defaulted to a very low compression. Much less than the original. I got in a hurry(gotta fix moma's car) :D
