IBrokeMyFreakinNeck
Thread starter- Joined
- Jan 3, 2004
- 142
Re: I hooked up the fuel line and turned the key, guess what.........
Stream is pumping great. I didn't do anything to the wires, yet. I found that they were taped together, pos and neg. But there are a couple that are just laying around. <br />I also have been busy with the trailer, as I sanded it and painted it today after running the motor. I still have the tilt/trim and tach to deal with besides the choke. Seems like nothing is wired.<br /><br />BillyOriginally posted by Unicorn:<br />You can check that choke solonoid easy by running a jump lead from the battery to the live side of the soloniod. It will "Click" if it's working. You NEED it to work when cold, because these Mercs like to be choked hard when cold. It may be just the way you've untangled those wires that's causing it to fail.<br />BTW How is the telltale stream looking ?
