How to align the flywheel on 197? 402 merc
mom987mercury
I have a 197? 402 mercury outboard.This engine runs extreamly well,except that it was pull start only,well i removed the other flywheel and replaced it with an electric start flywheel,but also kept the pull start mechanism on the engine.The problem is that i did not pull the other flywheel off,i just unbolted it but i did not mark the location it was removed so i have no idea how it goes on to fire properly(not smart).When i pull it over it wants to start but the engine pulls the pullcord out of my hand.Please Help... :confused:
rickdb1boat
Re: How to align the flywheel on 197? 402 merc
Was the flywheel not keyed in??
dilligafda
That model "should" have a keyway in the center hub. Or did you leave the center hub on the crankshaft and remove the outer hub to get the ring gear portion on? (I hope not, it's a real pain to get the flywheel lined up again!) <br /><br />Let us know!
mom987mercury
That is exactly what i did.I thought bo leaving the hub on that i would save a lot of time..WRONG..
Clams Canino
turn the crank till #1 is at TDC. Then put the flywheel on so the decal hits the pointer the same way. You only get 8 choices - LOL<br /><br />-W
mom987mercury
I know the decal you are talking about on the flywheel,but i dont now the pointer you are refering to.But thanks for the input. :D
Troy_from _Oz
I think that there would be some indicator marks on the flywheel that indicate where TDC is. These are the marks that should be lined up with the TDC marks on the decal. On my engine they are three small holes on the side of the flywheel - like those made from a centre punch.<br /><br />EDIT<br />Oops - sorry i just re-read your post and the penny dropped that the decal is on the flywheel - Sorry - My engine is a bit different. I just had a look in my book though and there seems to be a timing window on a frame around the flywheel (flywheel guard). at the top and bottom of the window is a raised section that seems to be the timing mark. Does this sound familiar?<br /><br />hope this helps.<br /><br />Cheers<br />Troy
Clams Canino
There's got to be some kind of indicator thingie to point at the decal on the flywheel. For timing purposes. That's the one. :D <br /><br />-W<br /><br />
Originally posted by mom987mercury:<br />I know the decal you are talking about on the flywheel,but i dont now the pointer you are refering to.But thanks for the input. :D
mom987mercury
Thanks guys,it is 9.00 here now so i will try to look at the timing marks tomorrow and let you know how i made out.Thanks so much.Remember,it's not the size of the worm that catches the fish,it's the way he wiggles.... :cool:
Chinewalker
You may have to put the recoil back on to find the timing mark...<br />- Scott
