flywheel puller
timmytes
what type of flywheel puller do i need for a 99 125 merc. can i purchase it from a parts store, or do i have to get it special from mercury?<br /><br /><br />thanks
Barnacle_Bill
Re: flywheel puller
I use a harmonic balancer puller on my 83 150. Never a problem. Available at your local auto parts store.
rmperryjr
Re: flywheel puller
I don't recommend a harmonic balance puller because it pulls from the sides. This can break your flywheel. I bought the special puller from mercury to pull the flywheel off my 150 merc. It was money well spent. Cost less than a new flywheel. I'm an automotive technican and believe in the right tool for job. The mercury tool threads in the center of the flywheel and pulls from the center against the crankshaft. Works great. I only used it once, but I had to have it to do the job. Good luck with your repair.
rabidfish
Re: flywheel puller
I have one for sale. I'll take $35.00 plus shipping for it. New they are $ 77.50 ( part # 91-849154T1 )Email me...
Barnacle_Bill
Re: flywheel puller
I think you are referring to a pully puller. My harmonic puller uses 3 bolts and attaches to the flywheel in the center. It works the same way as Merc's $77.50 puller except they are only $15-20. I do agree, never try to pull it from the edges.
b20
Re: flywheel puller
i drill a piece of 1/2"steel plate and use a couple of high-tensile bolts and a 'forcing screw'.work a treat.very similar to a harmonic balance puller.
rmperryjr
Re: flywheel puller
The mercury factory tool has two small torington bearings in the end that fits against the crank. This keeps the crankshaft from being damaged. My '83 150hp v6 didn't have the holes you need to use a harmonic balancer puller. Wish it did, I have one of those.
KCLOST
Re: flywheel puller
Here's a cheap idea, if you have a lifting eye...<br /><br />
timmytes
Re: flywheel puller
any ideas how to hold the flywheel in place to loosen the nut on the top of it???
flips
Re: flywheel puller
try a rattle gun works ever time.
rodbolt
Re: flywheel puller
hello<br /> I use a snap on flywheel holding tool. for limited use a strap wrench is only 20 dollars or so.dont use that "rattlegun" for installation no matter how tempting :) .
rmperryjr
Re: flywheel puller
I recommend purchasing the repair manual for your engine. It has great photos and much needed information, like torque specs.
