Re: 80hp mercury 3cyl
Check carefully the oil seals under the water pump as they are the most likely suspect for leakage. Also the shift shaft but my money is on the pump seals.<br /><br />If the prop seals were bad you'd likely see external leakage of gear oil, whereas bad oil seals under the water pump will cause a lot of oil to be 'sucked' out of the gearcase and replaced by water.<br /><br />ps replace any seals or soft goods on whatever oil-containing parts you disassemble from the lower unit.<br /><br />HTH and G'luck............ed
