80hp mercury 3cyl
bgmdad
when I start the engine I have a milkey oily water combo coming out from around the rear of the propeller and out of the louvers behind the trim tap bolt.<br /><br />What is wrong and how do I fix it.<br /><br />thanks, Bobby
Laddies
Banned
Re: 80hp mercury 3cyl
First you need to ck the lower unit oil to see if its comimg from there, but it really sounds like unburned fuel mix, does the engine run aright?
bgmdad
Originally posted by Laddies:<br /> First you need to ck the lower unit oil to see if its comimg from there, but it really sounds like unburned fuel mix, does the engine run aright?
bgmdad
The engine runs fine, is there seals in the lower unit that keeps the gear oil from mixing with the inlet water?? if so how do I go about replacement.<br />Bobby
Laddies
Banned
Just open the drain screw to see that the oil is no contaminated
bgmdad
Originally posted by Laddies:<br /> Just open the drain screw to see that the oil is no contaminated
I did that and yes it was contaminated.I pulles prop off and pulled the propshaft housing out.There is a O-Ring on the back of the housing,is that all I need to replace or should I drop the lower unit is't self and replace any seals or O-Rings along with the water pump?
emckelvy
Check carefully the oil seals under the water pump as they are the most likely suspect for leakage. Also the shift shaft but my money is on the pump seals.<br /><br />If the prop seals were bad you'd likely see external leakage of gear oil, whereas bad oil seals under the water pump will cause a lot of oil to be 'sucked' out of the gearcase and replaced by water.<br /><br />ps replace any seals or soft goods on whatever oil-containing parts you disassemble from the lower unit.<br /><br />HTH and G'luck............ed
