1988 60hp -->>>> 3 ring vs. 2 ring Pistons ... Help ...
AMD Rules
I ordered 2 replacement piston for my motor, and am concerned that I've ordered the wrong parts. <br /> <br />Original pistons had 3-rings <br /> <br />Replacement standard pistons have only 2-rings. <br />Motor s/n OA732655 <br />I ordered part number: 774-9137A12 Qty (2) <br /> <br />Of course, I was planning on re-using one original piston but it has 3-rings. <br /> <br />Can I mix & match pistons like this <br /> <br />Will my new rings (39- 78816A12) fit the original 3-ring style piston?
jheron
Re: 1988 60hp -->>>> 3 ring vs. 2 ring Pistons ... Help ...
hehe on my 1976 115 tower the original pistons had 2 rings and the replacments had 3 :) All three rings were identical with mine. I have heard that the guys who race them run them with only 2 :D <br />Jon
AMD Rules
Thanks for the advice. I've found out that he pistons are interchangeable, but the rings are not. Lucky for me I accidentally ordered the old rings for my 3rd piston. The 2-ring pistons use a much wider ring.<br /><br />Thanks again.
jheron
Man that was lucky eh! Gotta love it when a plan comes together eh? do you have a good ring compressor? If not a beer can sliced in half and a tyrap work great :D
AMD Rules
More great tips.... I have a full can of Keith's in the fridge. I'll fix that quick!<br /><br />Now if I could just get the wrist pin clips out....
jheron
Man thats funny it was a Keith's can that I used :eek: :eek: <br />Make sure you oil up the can and piston well! I lined up the slice in the can with the top ring end gap and marked the other ones so I could tell they were lined up properly when I set them. slide the tyrap up from the bottom of the piston and before you get rite up to the rings you can still slide them around to line them up :) <br />I used an awl to get my clips out but putting the new ones in was a *****, if I had to do it again I would buy the right tool.<br />Jon
AMD Rules
Yup.... I have the old ones out (bent), and the new clips in. Definitely wouldl buy the right tool for installation, next time!<br /><br />Chug...chug.. (B) <--- beer :)
jheron
where do you go boating? I drive by beamsville on almost a daily basis. <br />Jon
AMD Rules
Just moved back to this region.... only had this boat on the water once! Launched out of Grimsby (L.Ontario).<br /><br />Formerly boating on Lake Huron, with previous boats.<br /><br />Thanks for your help!<br /><br />
AMD Rules
132 psig <br />130 psig <br />130 psig <br /> <br /> <br />WOOOOOHOOOOO !!! <br /> <br /> <br />Started right up, although smokey as it is full of fogging oil & I have doubled up on the oil mix for the moment. <br /> <br />Idles 100% better than before (no shakies). 10:30pm so I couldn't run it too long before my neighbors called the police....lol <br /> <br />What's the appropriate break-in process I need to follow after a re-build ? <br /> <br />I am on holidays...and my boat is coming with me!!!
AMD Rules
Pictures say it all.... <br /><br /> <br /> <br /> <br />Boat ran great, having gone through about 2 tanks of fuel so far. I did however find a large boulder near the beach, when anchoring. Prop lost about 1/2 a blade. Ouch!<br /><br />
