Re: battery not chargin on 150 91 mag 2 xr4
Hi Casey1. I have been having voltage problems with my 1994 200hp. First check all the obvious. Loose, corroded or burnt wires. Take your batteries to an auto parts store and have them load test them. The SELOC manual I have gives a real good check out of the voltage regulators, If yours are bad it will tell you. If you don't have the book, I suggest you get one. All you need is a cheap volt/ohm meter. My problem is intermittant so it is harder to diagnose. If mine would stay broke I could fix it. With no charging at all it could be your Stator, rectifier, or regulator. You need to check them one at a time.<br /><br />Also, how do you know it is not charging? Do you have a guage on your dash? What is it telling you?<br /><br />ED
