Premix vs Oil Injection
Status
Not open for further replies.
Re: Premix vs Oil Injection
a good thing about oil inkectors is that the fuel in the tanks will last twice as long as premix.
dajohnson53
Originally posted by snowmobilefanatic:<br /> a good thing about oil inkectors is that the fuel in the tanks will last twice as long as premix.
I don't follow this.
BillP
...because the motor isn't running because it froze up when the injection system quit working? <br /><br />That's a good way to get oil to last twice as long. If you don't fix the motor just think how long the oil will last? Interesting concept. <br /><br />I couldn't resist.<br /> :D :D
phatmanmike
if you dont like the stink and the smoke, run a high quality synthetic oil.
rottenray6402
Ensign
I always premixed in a 6 gal jerry can and then siphoned it into the main tank. I never trusted how well it would mix in the big tank and never knew how many gallons it would take to fill it.
Kylie
I am running a 1989 Mariner 175 (efi) ski V6. Previously oil injected removed by previous owner. I have been using premix synthetic oil at 50:1. Engine is great at full throttle. At idle she burns oil and fouls the plugs making starting difficult. I am returning to oil injection because the engine requires a variable amount as set by the ecu.
AguaSki
I agree. I like shaking the can well to confirm proper mixing. I also use one of those measuring bottles available just about everywhere. This gives me an exact 50:1 mix everytime.
rodbolt
that mixing in a jerry jug is great, however last febuary I got to put a 28ft mako on a string due to mechanic/owner ignoraance.<br /> wind was 30 or so out of the southwest.<br /> I was running from colington back to kitty hawk. right of the dock of the bay channel was the boat dead in the water and dragging anchor towards the mudbank.<br /> got a line on him and dragged him back out to thick water.<br />boat had a pair of 95 225 jonnyrudes.<br /> the mechanic did a tune up and convinced them that if they left the VRO rather than routine replacing them, they would spend eternity in purgatory.<br /> the boat held 225 gallons, they had dumped 4 gallons of oil in and added the gas.<br /> problem was the oil sat in the tank like a turd in a punch bowl. just as they entered the bay both fuel systems filled with solid oil and shut down.<br /> like I say, I see far less problems with a well maintained oil injected rig than any premix with built in tanks.<br /> neglect it and they all die.<br />like the guy that tells me the water pump is 10 years old and suddenly failed.<br /> I explain no it worked a year and took 9 to take out a piston, and by the way the pump costs the same.<br />my reccomendation on the VRO/OMS is test the alarm system at least every six months, make sure it always self tets and replace the pump every 6 years.<br /> inspect the lines and tank filter at least yearly. goes double for mercs on the lines.<br />the V mercs run a nylon gear, every gear failure I ever saw was accompanied by a rusty driven gear that ate the drive gear due to improper storage.
Captain Tuna
I am totaly confident premixing my 6 gallon portable tanks. I have 4 tanks and a funnel; left over premix from one or more low tanks is added to another low tank. Only empty tanks and the appropriate number of pint bottles of TCW-3 are taken to the gas station. I pump in one gallon of gas, add oil, pump in five more gallons. Exact routine every time every tank........
If I had a large engine and built in tanks I think i'd prefer oil injection..... Hell, I probably check the door to the store at least three times before I leave to make sure I actually locked it........ I would premix a large built in tank if I had to, I just wouldn't like the second guessing. I can almost see myself paying a premium for the pint bottles so that I could read the pump; 24 gallons of gas, four empty bottles of oil on the deck.........
Status
