good impeller....no pee!!!???
pinboy122
read until my eyes popped out and still cant figure this out.while getting my 95 60hp ready for the season,i hooked up water and no pee.I thought maybe impeller got screwed up over winter so i pulled unit and impeller looked great.cleaned everything up,reinstalled and still no pee.The hose isnt clogged.any thoughts?
WillyBWright
Re: good impeller....no pee!!!???
Welcome to iboats. :) <br /><br />We had a weird one come in last week. Same thing, out of the blue. Took the gearcase off and the top of it was covered with those dang orange Lady Beetles, even filled the water pump. A backflush thru the thermostat opening (gearcase off) and a new impeller took care of it.<br /><br />Are you sure you got the connector in place above the water outlet on the pump? Or maybe the key on the shaft slid out as you installed the impeller? Is water coming out of the prop hub when the motor is running on the muffs?
Motor Boater Bill
If your motor has the thermostat and poppit valve arrangement, I suggest you search for those terms on this board. It is a somewhat more complicated "circuit" and troubleshooting it is different than for motors that don't have these. It was very well explained in a fairly recent post.
studlymandingo
How long has it been since the last impeller change? Where are you located? (Is it still cold there?)
pinboy122
wow fast response,thanks!the connector is in place,also i had no problem in the fall.the impeller key is also in place but seems to be just a little loose ie.the impeller will turn back and forth about 1/8th each direction on the shaft.pee hole is clear.impeller was changed by previous owner 2 yrs ago.i will search on poppet because i dont even know what it is hehehehe.over the weekend i will remove thermostat and flush.I hope a big piece of crud comes out because if it doesnt ill be stumped.fyi,im an above average wrench with below average outboard knowledge.i do really appreciate your input.great site
rickdb1boat
The impeller should not turn 1/8 of a turn on the shaft....Sure it's the correct key?
pinboy122
went back out tonight and pulled lower unit again.i also removed the thermo/poppet housing.everything looked ok.i think the impeller is partially wore out due to the fact that it moves on the shaft and the rubber vanes have a distinct curve set into them.is it possible that some built up scale has blocked a passage?when i flush,should i go from bottom(water tube)up or thermo housing down?the part that bothers me the most is that none of the parts are that wore out or dirty to warrant no pee.the water pressure from the hose should push at least a little water through the system.i have no pee and also no water through hub.i just want to pee is that too much to ask?????........sorry AL
studlymandingo
If the impeller is 2 years old, replace it. They can look ok but not really be. Do that 1st.
MercFan
Flush from the top somewhere to the bottom. What ever is stuck in there came from the pump. Flush it back into the pump and out.
studlymandingo
Water pump kit..............$42.99<br /><br />Thermostat kit..............$32.99<br /><br />Peace of mind...............$Priceless
gungalunge
i had rubber peices from an old pump impeller blocking passages when it few apart look in there with a light
studlymandingo
Right gunga, that's why you replace them before they look worn.
pinboy122
thanks for all the tips,i flushed the motor with the hose from the thermo down.while nothing of any size came out,it did the trick.im re-using the old impeller untill the new one comes in.thanks for all your help!!!Al
oz57
I too had a no pee Mariner. A mud dobber had filled the pee hole on my 25 horse with mud.
gungalunge
I am all for the maintance.My engine was a project that i intercepted form a work buddy.It was a mess I had to start over with a differant engine block and have it boored. But yea studymandingo How right you are never let it a water pump go bad .. #1 cylinder had a hole right though the block it got that messed up.
