BassAssassin
- Joined
- Feb 2, 2005
- 48
Ok first of all i want to thank everyone on this board. You guys are truly sent from god. <br /><br />After i fixed my last problem, with the help opf this board i ran into a new one. I have a lot of trouble coming out of the hole shot. it used to take me under 5sec to hit the throttle and be on plane. Now it will plow water for awhile and then gradually gets up on plane. i would say what took 5sec before now takes 15 - 20. The top end seems fine but might have lost a couple mph, nothing drastic though. The prop and everything else is the same i havent changed anything that would effect the hole shot. i have read other posts and found that it could be my fuel line, back pressure in the tank, fuel pump, and a few other things. What worries me is that on startup only it makes a weird noise that i have no way of explaning. the closest thing i can think of would be the tail end of a donkey's eeehhh-AAAAWWWWHHHHH. Its like backpressure releasing or something. The compression when cold is from 104 - 113. i thought the sound could be my reeds going bad so maybe a leakdown test is in order. Has anyone ever had a weird noise like this on start up? Any suggerstions on where to start would be greatly appreciated. thank you.
