water pump
sparky48
hi just installed a new watewr pump but nedd help pump work fine but only have forward no have no n reverseplease can some help me out thank you mark
sparky48
Re: water pump
hi mark agian heres what i ment i just installed a new water pump but i only have forward and no reverse or N CAN ANYONE HEWLP ME OUT
GA Paramedic
Re: water pump
are you saying that after you installed the water impeller, you now have forward but no reverse gear? If so, do you atleast have water peeing out of the pee hole?
AMD Rules
Re: water pump
1) Remove your lower unit.<br /><br />2) Determine what gear position the lower unit is in.<br />... Neutral - prop spins freely in both directions<br />... Forward - prop wont turn counter clockwise and will ratchet clockwise<br />... Reverse - prop will not turn either direction<br /><br />3) Adjust the shift selector on the motor to match whatever the position the lower unit is in.<br /><br />4) Re-install lower unit.<br /><br />5) Go boating.<br /><br /><br />(p.s. it sounds like you installed the lower unit with the gearbox in forward gear and the selector handle in neutral. It happens all the time.)
