FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
are you saying that after you installed the water impeller, you now have forward but no reverse gear? If so, do you atleast have water peeing out of the pee hole?
1) Remove your lower unit.<br /><br />2) Determine what gear position the lower unit is in.<br />... Neutral - prop spins freely in both directions<br />... Forward - prop wont turn counter clockwise and will ratchet clockwise<br />... Reverse - prop will not turn either direction<br /><br />3) Adjust the shift selector on the motor to match whatever the position the lower unit is in.<br /><br />4) Re-install lower unit.<br /><br />5) Go boating.<br /><br /><br />(p.s. it sounds like you installed the lower unit with the gearbox in forward gear and the selector handle in neutral. It happens all the time.)
