1991 Yam 60Trim/Tilt Problem
Explorer 4x4
Hi, I have a 1991 Yam 60 that when trimmed or tilted up will creep back down fast enough to be observed. I have been told it's the non return valves. Are these repairable as I have been quoted lots of money for a new one! :cool:
rodbolt
Re: 1991 Yam 60Trim/Tilt Problem
hello<br /> can be a lot of things.<br /> could be the manual release valve could be a main valve or a bad oring on a piston.<br />its not a terrible job to disasemble it and repair it. is yours the singe ram system or the three ram><br /> some were tilt only.<br /> good luck and keep posting but i would opt to repair the unit if it was not corroded away.
Explorer 4x4
It's the three ram type. It's in good condition with little corrosion & no fluid leaks.
