2 gaskets
tori0701
This is another ROOKIE??? To replace a head gasket do I have to replace the head cover gasket.
Ray Neudecker
Re: 2 gaskets
Not if you don't take the head cover off, normally no good reason to. If you remove the head clean all surfaces well and replace with a new gasket. Torque to specs.
tori0701
Re: 2 gaskets
So I just seperate head gasket plate not the the other plate and how do I clean it smooth it and can u tell me the torqe specs.
tori0701
Re: 2 gaskets
Originally posted by Ray Neudecker:<br /> Not if you don't take the head cover off, normally no good reason to. If you remove the head clean all surfaces well and replace with a new gasket. Torque to specs.
