Re: DT175 Problems
Ok sorry for the long delay but I've been working nights.<br />Well I removed carbs again and cleaned again. (no problem found) Bought and replace both fuel pump diaphrams and used separate tank with clean fuel oil mix. Engine starts but runs very weak. I systematically pulled each wire and found #1 and #2 cyllinder to be the only one firing. ( the others had no effect to engine rpm. While engine was running I sprayed premix into cyllinders with no success. Next I disconnected all of the ignition coils and checked per the clymers manual. All primary sides of all coils read .8 ( spec = .3-1.0) But the secondaries read as follows #1= 27300 , #2= no reading #3= 21300 #4= 216000, #5 no reading , #6 no reading. Can this be right and what does it mean? I would think if the readings were real #2 cyllinder would not be firing.
