Ed O'Neill
- Joined
- Apr 9, 2005
- 13
Started the engine this morning and it would not emit water from the small **** hole. I turned off the engine waited a moment and tried again. No luck the engine would not emit water from the small **** hole. I pulled the boat out of the water and attempted it again on land with "earmuffs". No Luck, I inspected under the cover and there were no broken water lines. I dropped the lower unit and the water pump was fine, the impeller was nearly perfect. <br /><br />Any ideas? I was thinking maybe its a bad thermostat ?
