Yamaha 100 Tensioner
kkilloy
After the engine warms up and after crusing at about 4000 rpm for 10 or more minutes, I pull back to idle (in gear or out of gear)and hear a faint squeaking noise. I has been doing this for over one year and is getting no worse. The timing belt looks good to me. I was wondering if there is an adjustment to the tensioner. I have the repair manual and I can't find one. The tensioner does not appear to be pulled by the spring or do I just not understand how it works. I don't even know if this is the squeak. Thanks for your help. This is a great forum.
Anymec
Re: Yamaha 100 Tensioner
I think it's the driveshaft bushing.
Propnuts
Like fin says...the drive shaft bushing may need attention. The timing belt tensioners are not adjustable.
rodbolt
what model do you have? most the large 4cyl motors are twin cam with an ajustable tensioner. all the F100's I see have the same set up as the 115.<br /> but most likly your either hearing the driveshaft bushing squeak or you have a belt that just makes noise, I have seen several that made noise at low speed. if all is correctly adjusted it just is what it is.
