Removing Lower Bearing From Crank & Replacing
boatmon345
Rebuilding 1997 Yamaha 150HP 2 stroke S150TXRV powerhead.<br />( Click here to view updated blog with new pictures )<br /><br />Clymer manual says "Install a universal puller plate....Use a piece of hard plastic or wood to protect the crank surface from the press. Suport the crank and operate the press to push the crank from the bearing....<br /><br />Where do I get one of these universal puller plates? I don't think I can use the puller I used for removal of the flywheel but not sure.<br /><br />Secondly, book does not describe how to install lower bearing. HELP. <br /><br />Thanks.
Ray Neudecker
Re: Removing Lower Bearing From Crank & Replacing
It is not really what you would think of as a puller, an adjustable plate to press bearings off with. Sort of like a pie plate with an adjustment for size. Parts house item. You press it back on.
rodbolt
easiest way to reinstall it is to heat it with a heat lamp or toaster oven then making sure the numbers on the bearing face the correct way slip it on while hot I have seen it done with a fry daddy set at 275*F as well but its much messier.
boatmon345
I picked up a beauty of a used crank today for $500 (with bearing and oil pump gear) decribed and appeared as "low hours". Lower bearing is tighter and no rough operation. <br /><br />So I suppose no need to transfer out lower bearings. Let me know if you disagree...<br /><br />Thanks for the info.
rodbolt
I disagree
boatmon345
Machinist says "mains never go". I'm just the middle man.
rodbolt
mains rarely do, bottom bearing suports an axial AND radial load, they fail.<br />bottom is ball and the rest are roller.
rodbolt
in fact as your going on the cheap best thing I can do is wish you luck and never reply again
boatmon345
:rolleyes: <br />I'm just trying to figure this all out.<br />Not cheap. Cheap is $2000 (lol). I'm $2.5k so far for parts. $0 for my labor.
bigshrimpin
I don't know if the 2.6L crank is the same in 1987 as it is in 1997, but I have a mint crank w'bearings for sale on ebay $225. <br /><br /> http://motors.search.ebay.com/_W0QQsassZreelQ5fadventure <br /><br />
<br />
<br />
boatmon345
Thanks...it looks the same, but, my engine is all back together now. That is a good price even without the bearings. You should be able to find someone to buy that no problem. Shoot, maybe I'll bid on it for a spare, lol.<br /><br />Why are you parting out your eng...did you blow somefin on the port side?
