150hp.force trim/tilt -repaired kit for $4.00
oogaboga
valve body on 150hp force power trim/tilt everyone said it cant be rebuilt all so the book said it.But you can even the pin or needle oring can be replaced allmost got new one.just thought you would like to know.NO MORE LEEK DOWN
sony2001
Re: 150hp.force trim/tilt -repaired kit for $4.00
Where can I get the parts. And whats their part number :cool:
oogaboga
went to auto zone and got 2 o-ring kits and compleatly rebuilt valve body even the pin valve but no srings .my book said it was unservicable well its not
kannuki
is this the tilt cylinder or trim cylinder?? if so is it the sam as a 125 and how do you get the top off the tilt cylinder? im trying to do the same thing to mine
roscoe
I think he rebuilt he valve body under the pump, not the cylinder. Hopefully August will be along to tell us.
kannuki
ok well i have taken that apart already and the orings look good.im not sure what is leaking on mine yet
oogaboga
yes the valve body at bottom of pump is the one I,m talking about.but be carfull once you have it off.there are 4 more bolts that can be removed but under spring presure so be carefull and good luck
oogaboga
after you take the valve body off there are 2 allen screws one on each side remove and take off the end cap but be carfull sring loaded and put new o-ring in and no more leak.well it fixed mine anyway and hope it will yours to. ;)
kannuki
there are 2 springs correct? one small one big?
oogaboga
Yes two -the big one goes in the hole that has and adjustment screw w/nut the little one goes in after you put ball in :) good luck
kannuki
ok you put the big spring in with the adjustment screw and the ball then the little spring? or does the little spring go somewhere else. i popped out when i was taking it apart and just guessed where it went. may be way tilt wont go down now
oogaboga
the little ball goes in little hole then the sring its opening is neer the center by the 2 gears -witch is were the other 2 large bearings go one on each side of the gears hope this helps :cool:
denniz
Awesome Job August.. you deserve a attaboy!!!! :D
kannuki
dude you rock looks like im tearing apart my valve body again tomorrow. thanks for the help
oogaboga
I,m glad this helps so many of us it took me 3 times before I got it to work ,and the book will show us nothing on this repair job .ya think they want to sell us a whole new pump.may the force be with us all. :p
kannuki
yeah right now ive go tilt up but no tilt down. and it looks like mine is still leaking down but i cant find what it is
oogaboga
Kannuki is your trim leaking or your tilt
kannuki
well both were leaking now just my trim. also does the little screw go over top of the little ball or does it go somewhere else?
kannuki
that is now just mytilt is leaking down, trim is holding fine
oogaboga
the little spring goes in after the little ball bearing.as the little screw goes you got me on that one, dont remember one being in mine-sorry- sounds like your lift rams have to be redone there not holding so there bleeding back -I,ll check into this and let you know.also did you replace both small o-rings in the valves with allen head on it. :cool: see ya latter
