150hp.force trim/tilt -repaired kit for $4.00
Jack7114
Re: 150hp.force trim/tilt -repaired kit for $4.00
What is a good online company to get a power trim motor for a 1995 force 90 hp..
oogaboga
Jack -Iboats.com-has a lot off stuff or get ahold of your local merc.dealer he should be able to help ya :)
kannuki
sorry about that i meant the spring not the screw. so the ball goes in the hole first or does the spring on the little ball? and what about the big spring does the ball go in first or the spring? oh and no i didnt replace the orings they all looked good should i replace anyway?
kannuki
on the subject of tilt rams. i found a place in town here that will rebuild them for 20 dollars each does that sound good or should i keep shopping?
denniz
August did you find trash in the valve body? Its not un serviseable they just wont sell parts to fix it.
oogaboga
20 bucks sound good-and yes replace the o-rings if your that far into it,also remember the ballbearings go in first then the springs,back off the big spring adjustmemt it will be easyer to install.and dont forget to change the little o-ring the one thats inside the big valve after you unscrew it from valve body this was my problem from the start. :)
kannuki
ok the balls go in the top before the spring? just trying to get this straight? and if i loosen the big spring adjustment how far should i tighten it back up? the big valve are they the ones that have a hex hed on them?
roscoe
Jack7114, is that a 3 wire motor? Napa auto parts has one, part number 18-6775. it replaces original part number 824051, '95-'97 90 hp.<br /><br />If you need one online, try this one.<br />It is the second one from the bottom of the page.<br /><br /> http://www.outboardparts.com/chrysler/mall/trimandtilt.htm
Jack7114
Thanks again Roscoe you found it you've been a big help... :D :)
kannuki
dogboy8
The big valves with the hex heads are usually the ones that cause the leak down. Once you take them out you have to take them apart. the end where the little needle valve comes off (you will need to pry it off with a wide bladed screwdriver, carefully) Inside is the needle valve with a spring under it, and the o-ring goes around the pin, Mercury part # is 820719. It is some sort of carb seal, but it does the job<br />Greg
JTC7579
If you guys could cover the issue with the springs and bearings a little more clearly I would sure appreciate it. My motor will not tilt down and I think I did not put the little spring in the correct place as well.<br /><br />Thanks. (Motor tilts up great now :) )
lmoore101
Ok not to beat a dead horse but I tried to fix my tilt/trim leakdown problem and now I have parts that I can't put back together and don't appear to be anything like the ones described in the post. <br /><br />The motor is an 88' Force 125<br /><br />Here are two pictures one of the parts and one of the valvebody. I don't have any O rings just springs, ball berings, and a few washers (spacers?)<br /><br />I labled the parts and where I think they were at I just need to match them up I.E. 2A, 1B 3C ect.<br /><br /> Trim Parts and Valve <br /><br />Any help would be great! Also should there be O-rings somewhere???
