Engine model number
markhodges78
I have 2 engines I am trying to locate model/ year of production for the serial number of the first 1 is R8180101 it is a 25 hp Tracker / Evinrude
The 2nd one is R8225860 with a partial model number of E100S it is a 100 hp Evinrude I have posted pictures as well IMG_0919.jpgScreenshot 2025-04-11 153153.png
JimS123
The cowl will provide no insight. There should be a plate on the transom bracket that will tell it all.
JimS123
A missing plate could indicate a stolen motor. Google OMCs database and look up your serial numbers. At the very least It would probably identify the year of manufacture.
markhodges78
It’s not completely missing
Post some ( 5 or 6 ) of the powerhead.----The 100 HP version was marketed in 79 / 80.-----Then again from 88 to 94.----And it could be that the later midsection was put on an older motor.----Or an older lower unit put on a newer motor.-----This is what happens with numerous owners !
markhodges78
Sorry----This may be a motor assemble from many sources.----I can offer no further help on it.
Bin working on outboards since 1968 or so.-----But , find a gray haired / caring mechanic in your area to help you with this.----Not many of those guys left I think.
