IQRaceworks
- Joined
- May 20, 2012
- 44
Well, I noticed a small leaking coming out of the Bravo 3 drive on my 99' Crownline 248BR. I saw that the small rubber hose that goes between the transom fitting and the drive had a crack on it, any was dripping drive lube. I read up on all the info I could find on replacing that hose and the one thing that everyone said was "the transom fitting is plastic.....DON'T BREAK IT when you are trying to remove the old hose.
Well....I thought I had the rubber line cut lengthwise where it attaches to the barbed end on the fitting where the hose would come off easy.....nope, the stupid thing snapped right of!!! Crap!
So now I'm stuck with trying to attempt to swap out that transom lube fitting. I got up under the engine hatch (good lord is it tight), and I can just barely get my head back under there enough to where I can see that fitting. I have no idea how I'm going to be able to reach it.
For those of you who have done this...any tips or tricks? I think I'm going to have to pull the steering cylinder and linkage off in order to have more access to the area I need to get my hand through to get to that fitting. Why in the world did Mercruiser make that fitting out of plastic!!
Any advice would be great!
