Open Water
- Joined
- Apr 28, 2025
- 10
I have a 1967 Evinrude 40 hp big twin electric shift. My issue is with milky lower unit lube. Had it air pressure tested and held for a full day. Fella told me it looked like the seal had been changed. I’ve changed lube a few times this summer, it’s worse after I run it in higher rpm’s. To me two things are different from pressure testing or in the lake. Drain and vent plugs and RPM
