2001 Chaparral 233 Sunesta Single Prop Size?
mckaras
How do I figure out what prop size I should use for my deck boat? It had a bad duo prop drive and I swapped it out with a 1.66 VP SX Drive and I wanted to know how to calculate what prop size to use. The engine is a 5.7 GL. Boat is 23 feet and dry weight is 3823 lbs Fuel Capacity is 58 lbs Top Speed on specs is 50 MPH
Scott06
If I had to take a stab I would say start with a 19" pitch see where your WOT rpm land and go from there. This may be cheating a little towards the holeshot or loaded down side but should be in the ballpark
It would be great if you could find a prop shop or dealer to let you try a couple as you may have to dial it in.
Not sure that boat will do 50 with a 5.7.
why did you not keep a DP drive?
mckaras
Luckily my VP dealer was able to point me in the right direction but they mentioned that other 233 Sunsetas use 17 pitch props for a single drive.
What ideal MAX RPM am I looking for when I have it on?
Scott06
Not sure of what the exact wot rpm range is for your engine but would shoot for 4800-5000
