WOT RPM Low. MAG350 MPI B3
gcarmich
My Mag 350 MPI only hit 3870 RPM with throttle lever all the way down. Clean hull. New valves, heads, injectors.
Could it be a linkage issue since I had to reassemble the linkage?
Scott06
Couple of things I would look at -
first yes of course it could be the linkage make sure it is opening all the way
Verify firing order and the the indexing of the distributor. There is a procedure that Mercuiser has for this if you google it or find it in the manual.
Compression test could be something simple like rocker arm being too tight
@alldodge would probably have some things to verify as well.
it could be a throttle linkage issue
it could be a fuel system issue
it could be a wrong prop issue
it could be an ignition issue
what troubleshooting has been done?
compression test?
fuel pressure?
does your motor have the crab cap?
are the injectors from Mercruiser or ebay or amazon?
gcarmich
compression test?
fuel pressure?
Haven't compression tested since new heads/valves. Can do soon.
Props are original.
Is fuel pressure available through VesselView and/or RINDA?
Has crab cap.
Injectors are OEM. Just recently serviced and tested good.
I'll reconfirm firing order.
And check linkage and ensure full open all the way forward.
Thank you.
Scott06
this thread has the indexing of dist
you test fuel pressure with a mechanical pressure gauge at the schroeder valve
verify the crab cap is in good order. get a new one if the old one is more than a year old
test compression with a known good gauge. should be between 140 and 150 psi on all cylinders
gcarmich
Does the fuel pressure change with RPM?
My crab cap is 2yrs old.
alldodge
Not enough to notice. it should be about 45-50 psi
Scott, it's a Merc so most likely 43 psi, Volvo Penta is 50-60
FP can change a few psi, like 40 at idle and 43 or so at WOT
Props are original.
What are originals and what rpm was being able to turn prior to motor work?
Depends on your motor serial number, most likely NO
Rinda should be able to provide injector pulse width
What is motor serial number?
