WOT RPM Low. MAG350 MPI B3
gcarmich
My Mag 350 MPI only hit 3870 RPM with throttle lever all the way down. Clean hull. New valves, heads, injectors.
Could it be a linkage issue since I had to reassemble the linkage?
Scott06
Couple of things I would look at -
first yes of course it could be the linkage make sure it is opening all the way
Verify firing order and the the indexing of the distributor. There is a procedure that Mercuiser has for this if you google it or find it in the manual.
Compression test could be something simple like rocker arm being too tight
@alldodge would probably have some things to verify as well.
it could be a throttle linkage issue
it could be a fuel system issue
it could be a wrong prop issue
it could be an ignition issue
what troubleshooting has been done?
compression test?
fuel pressure?
does your motor have the crab cap?
are the injectors from Mercruiser or ebay or amazon?
gcarmich
compression test?
fuel pressure?
Haven't compression tested since new heads/valves. Can do soon.
Props are original.
Is fuel pressure available through VesselView and/or RINDA?
Has crab cap.
Injectors are OEM. Just recently serviced and tested good.
I'll reconfirm firing order.
And check linkage and ensure full open all the way forward.
Thank you.
Scott06
this thread has the indexing of dist
you test fuel pressure with a mechanical pressure gauge at the schroeder valve
verify the crab cap is in good order. get a new one if the old one is more than a year old
test compression with a known good gauge. should be between 140 and 150 psi on all cylinders
gcarmich
Does the fuel pressure change with RPM?
My crab cap is 2yrs old.
Not enough to notice. it should be about 45-50 psi
Scott, it's a Merc so most likely 43 psi, Volvo Penta is 50-60
FP can change a few psi, like 40 at idle and 43 or so at WOT
Props are original.
What are originals and what rpm was being able to turn prior to motor work?
Depends on your motor serial number, most likely NO
Rinda should be able to provide injector pulse width
What is motor serial number?
gcarmich
Serial Number : 0W067905
Model Number : 4442077TS
Sterndrive S/N OW260110
Finally got a fuel pressure gauge with correct Schrader valve fitting. Fuel rail pressure is 34-36 psi. Seems to hold around 34 psi.
Still need to test compression
Still need to index distributor per manual instructions
Crab cap has less than 10 hrs on it but I can replace if needed
Linkage looks good. Wide open with throttle down as expected
I can check pulse width tomorrow with Rinda - what values am I looking for?
You have an issue with the fuel pump or regulator, should be 40 to 43 psi
FUEL PUMP Assy
The Reg is item 10
Fuel pump test procedure
No pliers pinching
Search the part number and one shows up for $12 on ebay
Don't know for sure but I'm thinking yes.
Reason is because Mercury no longer has it available either. Even superseded part is not available
and it looks the same as what is pictured in the cool fuel manual 40
Edit: no it doesn't look the same
Scratch that previous
Your connecting to the low pressure side with a Tee fitting
gcarmich
Thx. I found that advertisememt on a site but when I click through, it says item not found. If i can figure out the size and thread on existing connection, can i just insert a marine grade fuel cutoff valve?
Marine or Auto is no issue. Many of the fuel lines are same as auto and brake lines
gcarmich
13v dc on Cool Fuel electrical connector.
Ran fuel vacuum and pressure tests.
Fuel source test 5d showed 1-1.5 in hg vacuum (within spec).
For 5e test, restricted fuel supply and vacuum eventually reached 12 in Hg while rail pressure was 36psi. Rail pressure eventually dropped to 15psi as engine was starved for fuel.
From the test guide, i'm not sure what this indicates.
