I/O (Sterndrive) Conversion to Outboards
tpenfield
But if you buy outboards we won't have the continuation of this thread. I can see it easily reaching 100 pages on a refit....
This thread is appropriately titled as such . . . so it could certainly be continued šŸ˜†
Here is my quick cost estimate on a sell (338 I/O) then buy (338 OB) option . . .
Sell 338 I/O - $110,000
Buy 338 OB $249,000
Sales Tax $15,500
Travel/Transport $10,000
(as needed)
Fix-its/Upgrades $5,000
_______________________________
Net cost $169,500 :unsure:
The outboard conversion would be around 1/2 that cost.
tpenfield
Once I hit a 'commit-point' on the conversion, I may start a new thread for clarity. :)
Ted, the 338 I/O's selling down here are a bit higher than $110K. closer to $170K. However if you still go thru the conversion, Im still going to read the threads..... LOL
Lou C
I would sell and buy what you want….i just think there are too many unknowns that will take too long to resolve…I’d choose the biggest boat I could get with a 300 hp outboard & go with that….
Scott06
Buy 338 OB $249,000
Sales Tax $15,500
(as needed)
What's the break down on the conversion? I would have expected more $$
tpenfield
I don't have pricing on OB's yet (working on that), but my estimates are in the $85K range after fire-saleing the I/O's and doing the hull extension myself.
You are one of my dedicated followers. (y)
I am thinking that difference between asking price and selling price is going to be an issue. I have seen the 328/338's sit on the market when priced in the $170K range. In order to make the boat move, it would probably need to be at a low-end price. On the other hand, the OB's are more desirable and probably would command the prices that are showing.
I know the engineers that developed the Merc OB's (some used to work for me at one time) I will stick with I/O's
tpenfield
As far as outboard brands . . .
Mercury?
Yamaha?
Suzuki?
Which would you choose and why? :unsure:
alldodge
Merc
Easier to find someone that does work on them
Verado has good track record
Tariff cost should be less
redneck joe
I would guess most current inventory of all motors will be tarrif free. Outboards are notoriously slow velocity product so besides current inventory i would imagine they were part of the the Q1 and most of Q2 push to import before the tarrifs kicked in. If they did tell you they needed to add a tarrif fee I would be highly suspect.
Just my .05 cents worth of opinion from being put out to pasture early from a fortune 5 company in global supply chain. They didn't like people telling them the king had no clothes.
Lou C
Here it seems that the most easily serviced brands are Yamaha, Merc & Suzuki
tpenfield
Quick Update . . .
The Admiral and I discussed the $$,$$$ for the outboard conversion. She is OK with it, given the alternative cost of a sell/buy approach.
I am doing a little bit of materials research. . . If I build a hull extension/bracket out of fiberglass, I'd use fiberglass over foam core construction. Thoughts on core material?
  • Coosa Board?
  • Divinycell?
  • Maybe a combination of the 2?
There is a Coosa board supplier on Cape Cod, I may have to go a bit further for Divinycell.
Pmt133
Higher density coosa. The divinycell is nice but not nearly as strong for that application imo.
Nida core? not sure you need the higher density if you have a thick enough core. in bending, its the outer fibers doing the load.
could go carbon / fiberglass mix as well.
remember, your current boat has at least 3/8" (closer to 1/2") of fiberglass for the hull. fiberglass may be heavier than you want.
tpenfield
Why not aluminum?
Because . . . :ROFLMAO:
Actually, I have a plan in mind to make an exacting fit to the odd-shaped transom area. IMO, it would be much easier done in fiberglass than aluminum.
I tend to agree that the Coosa would probably be better because of the fiber content . . . and I can get it locally. (y)
Ted, since you would be having the fab work done externally if aluminum and you would have to build plugs/mold/parts if fiberglass, how is that easier?
