Harness to lift 9.8 4 stroke off and on transom while in yard
Crkgrl
Does anyone have recommendations how to make or purchase a motor harness I can use with my rear davits to lift the motor on and off the transom while in the yard? Being a small, but mighty girl, it's still a two person job. I would like to take the weight, literally, off my neighbors. :) Thanks for any help.
West Marine will likely have something on the shelf.----Find a marine accessories catalogue or give them a call.
alldodge
Could make one out of a length of rope
Wrap rope around under the cowling and tie off. Next run rope up one side to the other and tie off on other side
Crkgrl
Thank you. Wondered if I could make it myself. Balancing the motor correctly appears important.
alldodge
A 9.8 motor isn't that heavy (under 100 lb) so balance point not that critical
tphoyt
Is there any place to put a lifting eye on your power head?
cyclops222
Need a lot more description of your cruiser and Davits that raise and lower a stern mounted tender / lifeboat / inflatable.
What do you do with the motor after lifting up ? Set it down on what ? Then remove engine cover ?
