Harness to lift 9.8 4 stroke off and on transom while in yard
Crkgrl
Does anyone have recommendations how to make or purchase a motor harness I can use with my rear davits to lift the motor on and off the transom while in the yard? Being a small, but mighty girl, it's still a two person job. I would like to take the weight, literally, off my neighbors. :) Thanks for any help.
Honorary Supreme Mariner
West Marine will likely have something on the shelf.----Find a marine accessories catalogue or give them a call.
Could make one out of a length of rope
Wrap rope around under the cowling and tie off. Next run rope up one side to the other and tie off on other side
Crkgrl
Thank you. Wondered if I could make it myself. Balancing the motor correctly appears important.
A 9.8 motor isn't that heavy (under 100 lb) so balance point not that critical
cyclops222
Need a lot more description of your cruiser and Davits that raise and lower a stern mounted tender / lifeboat / inflatable.
What do you do with the motor after lifting up ? Set it down on what ? Then remove engine cover ?
km1125
You could easily make something with some 2" or 3" webbing (looks like lightweight seatbelt material) that you can get on Amazon. two loops, one going forward on the leg and one rearward of the leg, with both of them tied together on top of the motor.
