1986 Starcraft Mariner 160
Hello everyone! I saw a bunch of posts hear seems like alot of people have quite a bit of knowlage about working on old boats. I just purchased my very first non plastic boat! Really looking forward to doing som fishing off this thing but she needs some love. This is a 1986 starcraft mariner 160 powered by a 1993 murcury 60hp 2 stroke. Came with a spot lock trolling moter fish finder and trailer all for 2500 bucks. Im working on doing a semi restoration project. At hart its a fishing boat so it doenst need to sparkle but I want to fix it right. The trailer im working on needs new bearings and a rewire. It didnt run when i got it. Cleaned the carbs out and recoverd one of the batteries and got it running well. Theres some issues with the water pump I pulled the lower unit. 2 of the seals for the water pump were no good and i just ordered replacments. With the moter and trailer im thinking im good but I could use some guidance on the hull. So the wood for the deck is deffinitly solid. The transom seems fine but thats not my area of expertise. Im learning as I go along with this. I think my biggest issue is going to be the hull. There are a few pin holes and a few larger holes probably about a quater inch. I was thinking either jb weld or total boat makes this epoxy filler designed for hull submersion. One of my buddys who is more familier with boats reccomended painting the hull for an extera layer of waterproofing/ protection. I was going to go with the epoxy barrier coat underneath. It is already painted but it was a crappy rattlecan job. You can see where the pain dried as it was dripping of the rivits. Does anyone have a good way of stripping the paint. I was worried a grinder would burn through the hull.
Thanks, John
Heres the pictures I have. I can take more but I have it stored at my buddys house.
  • 20240317_134629.mp4
briangcc
I'll admit I am not an expert but that certainly looks like a lot more investigation is needed.
IF it were mine, I'd be stripping all that "gook" off the bottom of the boat to see what I was truly dealing with. My spidey sense tells me there's more lurking under that stuff...wouldn't be Flex Seal would it? Same for the stuff on the transom. That bubbling around the thru hulls tells me something is going on there too.
Anywho...the patch you see hiding under that "gook" would be the way I would approach it. Slather on a good helping of 5200 and then rivet it with solid rivets in place. This is not a place for pop rivets.
I appreciate the reponse. I have no idea if its flex seal or not. Im tring to figure out the best way to remove it. I also dont know much about rivets. Are the rivits you are refering to the ones that you only need acsess from one side? Im not sure if i can acsess it without pulling the deck.
briangcc
Yep. Solid rivets that need to be bucked. Special tool to do so and 2 person operation.
airshot
I would be very skeptical of those rough areas, gonna take some serious work to make it safe. Was she a salt water boat ??
I dont really have to much history on the hull. It seems like the patch is fiberglass though.
She lives.
  • 20250819_180244.mp4
I flipped back and forth on what to do with and decided to fix it up. Scraping all of the crap the previous owner had on it before was the hardest part. I used a combination of an angle grinder blow torch scraper and sand blaster to remove all of that. All of the corrosion appeared to be from the outside in due to saltwater being trapped under neath the bottom coating. I filled the very small holes with marine tex. The larger ones I drilled out to 3/16 or 1/8 of an inch and used closed end pop rivets with 5200. There was another section with larger holes in on of my first pictures where the guy ran something over. Patched this by riveting an aluminum plate covered in 5200. The whole bottom got and epoxy barrier coat as well as the transome. I put aluminum non af paint on the bottom as well as painted the top side. I have a lot of interior work I want to do but I want to see how well my repairs hold up first. Water test should be comming in a few weeks.
