Have a live mouse inside a interior wall. No insulation.
cyclops222
He is moving around on the floor stud. Should I wait for him to stop making moving around noise ? Then remove 2 T V outlet covers & the boxes.
Then pull him out with a stick and nail ?
Open to all ways of doing it.
Wife said let him die and dry out till odor, if any, stops. Leave him in the wall.
aspeck
You can always start blasting a shotgun in the direction of the noise and repair the wall later ... lol!
Jeff J
He will smell less and for a shorter time if you use a good poison.
redneck joe
410 is weapon of choice in this situation. Single shot cuz if you can't kill in one, you got issues,
redneck joe
We got invaded a few years back. A mouse can fit in a crack the thickness of of two quarters. These loaded with peanut butter will solve the problem quickly and kills instantly. Use zero poison or glue traps. If you gotta kill and not eat it make it as quick as possible.
dingbat
How did he get in there that he can’t get out?
Bacon grease or peanut butter on a trap should solve the problem
airshot
While shooting it may be more fun, trapping would probably be a better option. If you can't get access with a trap, they make poisons that actually keep them from stinking thru the chemicals they eat in the poison. Within days they turn to a clump of dust or powder. "D Con" was one of the first to have that feature, not sure if they still do...
Gee, when I tore out the paneling in a house I just bought, I found about 6 dried mice bodies, suitable for Egyptian tombs. I was happy to get them out.
redneck joe
Any cats, dogs, snakes, owls etc can grab these if they happen upon then while dying or immediately afterwards and poison themselves. With bait they will come out of the wall and get killed instantly. No need to kill innocent bystanders.
mouse trap with peanut butter on the trigger with a bit of string. put it in the wall...... wait 20 minutes, retrieve and toss.
tpenfield
This is what I use . . .
Along with some lock-able bait traps.
You should find out where the probable points of entry are and place the traps near the line of travel.
Grub54891
When I moved into this house there were mice everywhere. Trapped them all, went around outside and sealed every hole I could find. No problem for 10 years. Until last year. At the first sign of a mouse I setup traps again. Got a couple within a couple days, thought that was it. Checked the foundations again and didn’t find any entrance points. Well, 20 mice later, including baby mice that were still barely able to walk showed up on the basement floor, disposed of them and now no issues again. Dang sneaky critters!
airshot
Poster says mouse is trapped inside his wall and can't get out....otherwise I would agree with you.
airshot
I use "TomCat" appears to be same stuff from the label. They also have traps that contain the mouse, and traps that contain mouse and the poison if you go that route.
Mc Tool
Ensign
I had a mouse crawl into my recliner chair and die , stuck it funk , and despite pulling the chair to bit as much as I could I couldnt find it and it stunk the place out for over a month .
Oh once it was dry and crispy and didnt stink any more...... then I found it ....... down the inside of the cushion .
flashback
Bet you sat on him! Another brokenwood mystery. Lol
Mc Tool
Ensign
Almost , it was under one layer of leather and while it was soft I couldnt feel it but once the thing dried out and gone crispy I felt it .
Where have you been watching Brokenwood ? :):)
